March 19, 201214 yr I've got a MK1 focus hatchback and need a towbar as I've just done a deal on a trailer. Ideally I'd like a removable swan neck type to it's not visible when I'm not using it, so any ideas on the best (cheapest) place to get one? Cheers, Sam
March 19, 201214 yr I used to have a bit of dymo tape on my hard hat, it said. Fast, Cheap, Safe, pick two. But good luck getting a cheap (good) towbar.
March 19, 201214 yr Hi, I also have a Mk1 Focus, 2004 model, I don't know about detachable hooks, but I fitted my own standard one in about an hour not including the electrics (another ball of snot). They are easy to fit to these cars because the chassis is pre-drilled. The electrics aren't too bad, don't use scotchlocks though, no special electronics to worry about, go on do it yourself. the wiring you need to tap into is on the left side of the boot.
March 20, 201214 yr You don't have a location but in Yorkshire I can reccomend ECCO in Shelf between Bradford and Halifax. I had a Detachable Witter "flange" fitted for my Dave Cooper rack. £345 fitted to a Chevrolet Cruze. I should think the Focus would be cheaper as it's a more common model.
March 20, 201214 yr Author The towbars for the older focus model seems to be generally more expensive than the newer ones for some reason?! The towbar will only be used to tow this single bike trailer as I don't have a trailer license, therefore only upto 750kg allowed. I don't see how a cheap towbar can be that much worse than a really expensive one as a lump of metal, hardly much to go wrong besides it fiitting properly is there? Edited March 20, 201214 yr by rallymadsam
March 20, 201214 yr They have to meet MOT standards these days so you don't want to have to re-do it if it fails. Witter ones seem to be about £50-£100 cheaper for a Fixed one on a MK1 Focus than mine so you should be down Under £200 for a basic one. You only need a single electric one so that cuts costs. Remember if it fails you have the bike and trailer as well as anything it hits to worry about replacing. That could be a lot of money just to save a little. They are also guaranteed for life because of that.
