April 18, 201214 yr My carb was looking very dirty inside (a few specks of dirt) but the bike was running fine. So I too the carb off. Removed the float bowl and the two jets. Gave them a good spray with carb cleaner and rebuilt. then took the slider out and did the same. When i put it all back together and started the bike, she fired up as usual first kick but went straight to full revs for about 4 seconds untill the kill switch finally worked. Now the bike wont start at all Any help? so far... It kicks over fine with the usual amount of compression felt through the kick start No sign of even wanting to start I removed the drian bolt from the bottom of the carb and it was bone dry. Should it always have fuel in there and be wet? I put the high revs on startup down to burning off the carb cleaner?
April 18, 201214 yr You may have put the floats in upside down. Check that the pins are at the bottom. Steve
April 18, 201214 yr Author Nice one. Stupid error by me!!! Now she runs again but if i shart her from cold with the choke on she revs like crazy. With the choke off stil revs far too high. Any ideas?
April 18, 201214 yr Author I adjusted the throttle cable by about 6 turns and now she runs sweet. Thanks for all the help guys
April 19, 201214 yr I adjusted the throttle cable by about 6 turns and now she runs sweet. Thanks for all the help guys One should not need to alter this adjustment simply due to removing and reinstalling the carb top and slide. Cable is likely out of position on one end. Allways insure the slide slams shut before starting the bike. It makes an audible noise when it hits home. If you did install the floats upside down, you may well have bent the level tang on the float arm, putting things out of adjustment. Insure the arm is parallel with the bowl sealing surface with the carb inverted. Cheers,
April 19, 201214 yr Check foat level is 18.5 the cable might not be in the slide right or cable popped out above carb? As copey says always flick the throttle as a habit an especially important when refitting a carb.
April 20, 201214 yr Author I think that the throttle cable needed a few turns as I must have routed the cable a different route. The bike revs and ticks over nicely but will the float level effect the bike when out riding?
April 20, 201214 yr the float level is the amount of fuel available for the carb, too little and it will starve the engine of fuel, and opposite.
