May 1, 201214 yr has anyone bought the tank/seat unit from Majesty website, my Majesty tank fell apart on saturday (lugs for mounting rubbers fell off of tank !), has anyone had a sammy miller tank / seat unit, what are your thoughts, which should I get or any ideas for gluing lugs back on my exisiting Majesty tank (that would be lots cheaper, spoken as a true tight yorkshire man))
May 1, 201214 yr I've got the SM unit on a 175 and it's much wider than the frame hence catches on the breeks in an annoying way.
May 2, 201214 yr You could try and re fibreglass the lugs or use a two pack metal filler. Both are sold in Wilco's car parts. You should sand back the resin around the fixings to give a good key. If it was me doing it I would use the two pack metal filler as I have had some very good results with it.
