May 16, 201214 yr hi guys what ya think off my bantam trials project shocks are to big but just using them for an idea let me know i need feedback cheers mikey
May 16, 201214 yr have a look at yorkshire classic members section there are about 5 bantam 'conversions' on there. yours appears too short and too high. the swing arm needs to be much closer to paraell with the lower frame loop and you want a wheelbase about 50 inch ish
May 17, 201214 yr Author have a look at Yorkshire classic members section there are about 5 bantam 'conversions' on there. yours appears too short and too high. the swing arm needs to be much closer to parallel with the lower frame loop and you want a wheelbase about 50 inch ish hi there i have seen the other bikes, i was hoping for a short subframe with a high ground clearance but i know the shocks are far to big and the forks seem a bit big as well... thanks for info
May 17, 201214 yr to get the short subframe cut out the piece betwen the shock mount and top rail and shorten the arms that run under the seat so that they mount just below the original petrol tank mount.
May 17, 201214 yr forks all wrong, too long, tire will hit frame Might be a bit better if the forks were in the right way round.. just a thought.
May 17, 201214 yr Author the subframe has been shortened, and i know the front end looks wrong bit its how i have set it up with the fork legs the wrong way round it gives me more direct steering i have done this on my c15 too and it works great and no bother at all..
May 17, 201214 yr the subframe has been shortened, and i know the front end looks wrong bit its how i have set it up with the fork legs the wrong way round it gives me more direct steering i have done this on my c15 too and it works great and no bother at all.. You won't like the steering so much when the front tyre hits the exhaust pipe or the frame tubes every time you load up the front end
May 17, 201214 yr Author You won't like the steering so much when the front tyre hits the exhaust pipe or the frame tubes every time you load up the front end hi i know what your saying but it will miss i can tell you now i have had bantams befor and always worked them like this? maybe a mjust difrent but it works
