May 20, 201214 yr hi there any one useing these are they any good? http://www.ebay.co.uk/itm/221016087979?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
May 20, 201214 yr Yes, I have used those Goneli guards and they're ok, but not in that colour!! There is a neat trick of cutting the flap off the back of the front guard, trim it around to oval it off, you can make out the line it trims to in the pic, then used that end as the front. Like this There is a longer rear available, works well with the Cub. http://www.ebay.co.u...=item3376440cda Edited May 20, 201214 yr by Goudrons
May 21, 201214 yr I've used them , good quality plastic . In fact there is a spare white set out in my shop , along with another red rear for my son's TY80 that I made the exhaust cut out a bit to large ...on the first one ! Glenn Edited May 21, 201214 yr by axulsuv
May 22, 201214 yr I have them in white on my Montesa. I agree about cutting off the 'mudflap', mine got trapped in the wheel and snapped off. In Motion also have them in Silver.
