Con Rod Model?
Hi,
I have a new Sherpa con-rod - its 116mm length (centres), 18mm big end pin, 16mm small end pin.
Anybody know which model its off?
thanks
M49 conrod dimensions are 116mm centres, 18mm big end pin, I can't find the small end pin but the opening is 19mm
I think the rod changed around M91
The only other rod I have here for comparison is a M183 which is 116 centres, 24mm big end, 20mm small end pin
PS I only roughly measured the centres
OK sounds like one of those then. Many thanks.
