August 15, 201214 yr Does anyone have the part number (or sizes) of the taper roller bearings for converting the tiger cub / Bantam headstocks? Edited August 15, 201214 yr by suzuki250
August 15, 201214 yr I don't think there is a t/r set that will go straight into a Bantam headstock, you need to sleeve it to take a bearing.
August 16, 201214 yr Pyramid parts do quite a few "odd" sizes of TR bearings. Try them or Rex Caunt who is a bantam specialist.
August 16, 201214 yr . If you want Taper Rollers,Ray Small on 023 8069 3183 does them. It is a special with the outer race diameter reduced.
