August 30, 201213 yr hi what is the difference between the ty250 mono and the pinky version and which one would be the best to have cheers....
August 31, 201213 yr Pinky has front disc brake as standard and I seem to remember different rear shock and possibly slightly modded linkage. I had a pinky and before that a 1988 "S" model with modded air box and rear silencer as was usual, the pinky motor was probably a bit stronger but both were great bikes, you will not be dissapointed with any version if you can find one in decent condition. Hope this helps Dave.
