September 19, 201214 yr Hey all, I am rebuilding a M49 series one. I bought it in pieces and everything is just about back together but i seem to be missing the washer that sits on the gear shaft seperating it from the side case. I looked in the parts book to confirm there should be one there but dont have sizes. Would anyone have one to measure me the outside diameter, inside hole diameter and thickness? It is the earliest M49 with the oval side cases. Any help appreciated,,, Thanks, Mark G
September 24, 201214 yr Hello Mark, I checked, but my M49 has the newer style outer cases. I thought it might still have the washer, but it does not. You might try calling Hugh's Bultaco in New York (518) 851-7184, or emailing them at: info@buybultaco.com<info@buybultaco.com. Regards, John
