Is The Olle Rear Shock Recoverable?
Hi...
removed the swingarm, shock and linkages today. All needle bearings are in a bad state and partialy seized but retreivable with some effort / money.
More worryingly the lower "eye" and spring seat assembly on the olle rear shock is sitting at 5 degrees (or more) to the shock absorber shaft it is connected to.
It looks like the seized nature of the bearings has tried to bend the shock rather than compress it.
I have read that the thread between the shaft / lower "eye" assy can strip and be helicoiled. This is different but may be a variation.
  • Has this happened to anyone else?
  • Was it the shaft that bent or the thread in the eye assembly deformed?
  • How do you dissasemble the shaft / lower "eye" assembly
  • Its not obvious how to take the spring off the shock body?
  • Will the shock need re-gassing etc when this joint is dissasembled?
Any help is appreciated
What year is it?
Send it to Splatshop Chris for evaluation, still likely cheaper than a new one.
ps- Bad on you for neglecting linkage that long!!!!!! :beer:
the good news is that Chris from splatshop tells me that its rideable whilst i save up for another!!
Dom
Don't replace it with a Olle though, from looking at the site a Ohlins is actually cheaper & much better. No idea what a TRP cost now but have had 1 for a few years now & it was also a major improvement
  • 2 years later...
