S/arm
hi all the s/arm on my bultaco has had the bracket cut off on the s/arm where the top chain rubber gose. without taking it off and sart welding a bracket on. is there any easy way of mounting the ruber??
ruber glew? oar poop rewvits a berkit orn.
ruber glue sounds good. will it be strong enough to hold umm ill have to experiment cheers
:chairfall: :chairfall: :chairfall: :chairfall:
hello hewson any ideas on the s/arm ruber??????
Hi Chris,
back then when the older Bultacos did not have these swing arm protection rubbers feature we used a piece of a garden hose.
We cut the tube lengthwise and fastened to it with a hose clamp on the swing arm. I used a yellow one looks nicly to the blue
of the swing arm and works perfect.
