November 13, 201213 yr Hi guys, Can someone please remind me the standard settings - pilot jet / mixture screw AND idle / throttle stop screw - for the Amal carb on a 250cc model 150 sherpa It is on standard jets. Thanks very much. Max Edited November 13, 201213 yr by max
November 13, 201213 yr hi mate a good place to start is bottom the air screw then turn it 2 and a half turns out. then once the motor as warmed ajust the idle there really is no standard seting. its just trial and error.
November 14, 201213 yr Author hi mate a good place to start is bottom the air screw then turn it 2 and a half turns out. then once the motor as warmed ajust the idle there really is no standard seting. its just trial and error. Thanks Bondy - I'll give that a go. Cheers, Max
November 14, 201213 yr make sure you turn it clock wise to bottom it. then turn it antie clock wise 2 and half turns out. then go from here may need to turn the idle scerw in so it idles abit faster just to keep it runing. its pritty easy one you know. are you near livrpool? i would have had a look for you.
