April 3, 201313 yr hi all the 199B dose it have a difrant magneto than the 199A? i had the cover of and noticed its not threaded to take the magneto puller. its got motoplate writen on the magneto where these standard on the 199Bs? looking through the slots on the magneto the coils looks difrant to the 199A i can take a photo if needed.
April 3, 201313 yr There where two different magneto types mounted to the Bultaco Sherpas. Some magnetos came from Femsa some from Motoplat, the later Bultacos which where build outside Bultaco at the Derbi facilities came with all kinds of magnetos as these bikes where build from the remaining spare parts. A picture would ineed be very helpful. Here a picture of the Motoplat magneto that should be mounted to the Sherpa or Alpina:
April 3, 201313 yr Author hi patrick looks like the sme coil not sure about the magneto cant remeber i will take a photo tomorrow and post it. best regards chris.
April 4, 201313 yr Looks slightly different but shoud be the same as just the center is a little bit different in geometry. The other model mounted to the Sherpa is the Femsa, (on the upper left, slighty lighter):
April 4, 201313 yr Forgot to mention: The threads should be situated in the rear as seen here, when you unscrew the nut you will see them. You need a long extractor for this magneto. You find them f. e. here, or maybe from Bultaco UK: http://www.moninomartinez.es/cast/01extractores.htm I would measure the diameter and the threads of the magneto and of course the shaft lenghts sticking out bevor in forehand and give the spec's with the order just to make clear the Extractor will fit.
April 4, 201313 yr Author thanks i will buy a puller for it. i do have 1 but its for the 199A cheers patrick.
