April 14, 201313 yr Is there a preferred direction for insertion/removal and should there be any restriction on movement?
April 14, 201313 yr Hi Guys. Hi Penn? The clutch push rod will only fit from the clutch side??? You need to tell us a bit more about what year the engine is ETC. This little rod needs to be right on al years of C15 or you will get problems. Regards Charlie.
April 15, 201313 yr Is there a preferred direction for insertion/removal and should there be any restriction on movement? Crikey Penno, when I saw this I thought I'd landed on a different forum....
April 15, 201313 yr Author Oops! see what you mean, trials porn ha ha! Charlie the engine is a 1963 distributor model.
April 16, 201313 yr Hi Guys. Hi Penn. Has I say from the clutch side. The old Tiger Cub type push rod mech? I think you have to check that there is a suitable ball bearing in the cup for the lever unit. I will check for you and let you know. Regards Charlie.
