Which Paint?
Any thoughts on what's the Best heat resistant paint to use for painting my twin shocks engine? Also should I be using a primer?
Thanks on advance
recently used PJ1 and was very pleased with the results no primer needed BUT make sure that you follow what is said on the tin .
I've painted engines successfully multiple times in 40+ years of trials and never used a heat resistant paint. Quite simply, the engine does not get hot enough to require high temp paint. I typically use a good rattle can brand like Rustoleum in medium gloss black (not satin or gloss) for excellent results. Save the heat resistant paint for the exhaust pipe and muffler.
  • 1 month later...
