Will A Ty250 Twinshock Front Wheel Fit A Ty175 Twinshock
hi
will a ty250 twinshock fron wheel fit my ty175 twinshock just asking as i know the ty175 forks are only 30mm tubes
many thanks
Wheels front and rear are the same for both models along with brake anchor arms. Front brake cable is the same, as is the fender, or aftermarket SM brace.
Tony
If my memory is correct, I think they require diff spacers tho don't they ??
Yes as JC says, I think the spacer that fits against the brake drum side wheel bearing is a different length. No big issue but watch out for it
