2012 Sherco 290 Float Jamming
Has anyone ever had these problems? Or changed the kehin carb to a dollerto? Same thing keeps happening to my mates aswell. Thanks in advance for any information/help
You really said nothing in your post. Sounds more like you have a hard time installing the float bowl.
Add if you bent the floats or the standpipe in the process they will jamb! Requires adjustment!
jammed or overflowing?
Just overflowing? Few taps on the carb bowl with a rock and it seems ok. Really frustrating as it runs terrible when it happens
Sounds like you have the Bob Marley model!!
TLTEL
Sounds like the brass overflow tube in the floatbowl is causing the floats to jam as cope and others have said.
Look at chris's blog on the splatshop website for info on how to properly set the float height. Dont set it to 19mm as most places state.
There is an art to removing the float bown on a keihin, It's like a chinese puzzle on mine with the stupid angled brass tube.
This is common on the keihin but when sorted they are a great carb.
