Clutch Push Rod
Hi Guy's,
Just gone in on my M91 and replaced, mag side crank seal, and sprocket oil seal. I noticed the clutch push rod had the concaved end facing out is this right . should it be pushing on the ball bearing on the other side ?
Ball bearing end is meant to be flat. Left hand end is meant to be convex (domed outwards)
hello yes thats normal theres a ball bearing on both ends. theres a ball bearing on the end off your clutch arm inside your magneto cover nothing to worry about. cheers bondy
That's wear to the push rod done by the ball end due to too little slack of the clutch cable, or very much slipping the clutch while riding.
Ok, Thanks for the information.
cheers Guy's
