May 27, 201313 yr Just got the new Classic Dirtbike mag i have been following there rebuild to ride Bultaco this one is about fitting electronic ignition. one of the jobs on my list that seems to be getting longer, anyway at the end it says go to the classic bike club page to see live action of the test ride, has any one seen the video if so could you please post a link to it. All the best BR
May 27, 201313 yr I haven't seen it no, but it's not going to tell you anything about electronic ignition, all you'll see is someone riding a bike... It may fire up with the first kick but they'll do that on points too. The main reason most fit it is to do away with points maintenance, it doesn't transform the power of a bike to GasGas like levels, most you ca do is alter advance curves. I have a model 92, so does a mate of mine. One has points, the other electronic. If you rode them both you wouldn't know which was fitted with which. I'm not saying electronic isn't worth having, I've got it on two of my Sherpas, soon to be three, but don't expect it to transform the bike into a 280 GasGas
May 28, 201313 yr well said woody i agree ive had the electronic ignition on 1 of my sherpas and they dont make the bike any difrant. on the other hand they are good like woody says it takes the hassal of the points. witch is the way im going with my other bikes.
May 28, 201313 yr Author Hi Woody, Hi Bondy, Thanks for the feed back will leave electronic ignition till last then lot of other things need to be done first, im at the stage im not sure were to start i have lots of new bit for my 199A but it seems every time i have a closer look some thing else come to light im starting to think im going about this the wrong way round anyway found a club that run events about 25 mins from home so will try to make sure i have time to be at there next event Thanks for all your help and feed back BR Edited May 28, 201313 yr by bultacorock
May 30, 201313 yr Author I was trying to say i should have taken my bike to a few events before starting the rebuild
June 2, 201313 yr I was wondering what brand or brands of electronic ignition people were using and were there any to avoid as a friend has just had to send a faulty Yamaha one back to the UK. This has not been a speedy process and you would assume the reason for installing an electronic ignition would be the reliability issue. Also has anyone noticed the digital one for sale on Todo Trial with the inbuilt advance, for Montesa only at this point. Cheers Greg
June 2, 201313 yr hi bultaco uk sell good eletric ignition theres easy to fit to. Hey Greg - give Pete Bowker at Bultaco UK a go - I've got one going on the 198b shortly. Cheers Paul Mac
June 3, 201313 yr Hey Greg - give Pete Bowker at Bultaco UK a go - I've got one going on the 198b shortly. Cheers Paul Mac Thanks Paul , do you know what brand they are, some appear to have an advance curve programmed into them, There is not a lot of information about their ignition on the Inmotion siteCheers Greg
June 4, 201313 yr Hi Greg I'm pretty sure its an Electrex unit but I've had it a while unfitted - I'll check when I'm back (interstate at the mo...) Cheers Paul Mac
