lewis cosgrove Posted May 28, 2013 Share Posted May 28, 2013 Can someone run through how to do it Thanks Quote Link to comment Share on other sites More sharing options...
coops Posted May 28, 2013 Share Posted May 28, 2013 There's a good video on the trials UK website under the how to guides that shows step by step how to do it. Think you have to register to view it but takes a min to do. Coops Quote Link to comment Share on other sites More sharing options...
copemech Posted May 29, 2013 Share Posted May 29, 2013 Remove caliper(two large bolts), remove small screw and wire widget, pads out bottom. Reverse to reinstall. Quote Link to comment Share on other sites More sharing options...
charlie chitlins Posted May 29, 2013 Share Posted May 29, 2013 Before you take the old pads out, stick a fat screwdriver between them and give it a twist to push the pistons apart to allow for the thicker new pads. Quote Link to comment Share on other sites More sharing options...
zippy Posted May 29, 2013 Share Posted May 29, 2013 Before you take the old pads out, stick a fat screwdriver between them and give it a twist to push the pistons apart to allow for the thicker new pads. I usually remove the master cylinder cover when doing this to allow the fluid to go back into the master cylinder easier. Not exactly sure if it is necessary or helpful...........just something I do. Quote Link to comment Share on other sites More sharing options...
