Handlebar Risers
Ok back again for some more help
Because i am over 6ft, found that while riding most of my weight was goin forward onto the front forks, so after speaking to few friends they said "why no try some risers"
So got some apico fatbar risers to suit make and model
However, after removing old ones, went to fit new ones with 25mm lift adaptors and the bolts dont quite line up proper with the existing holes, just slightly of, Nothing wrong with the riser kit all fits together nicely but soon as i fit the handlebars to them they seem to go little bit squinty??
Hmmmm
I have managed to get them in but on closer inspection one side is about 2mm off
Has anybody else seen this problem b4 and is there any way to rectify it??
Sherco 2008 250 model
Cheers guys
footpegleg gm
Ask to Splatshop. There you can order lift. Thats rather cheap. I bought the same. I am 188 cm
Yes, seems some fatbar risers/clamps are 2-3mm off the Sherco pattern.
Hey thanks for that guys that seems to make better sence, should have looked here first, have had some stuff from them before
Bummer they are all out of stock will have to keep checking back
See if you may source some bolts in the meantime, cause you will need them. Splat Chris may have, may not?
OK scrap the risers
got new bars the bigger ones much better improved wheelie time too wohoo
