July 16, 201313 yr Hi all have a 2013 cabistany sherco just done oil change do they have a washer on the oil drain bolt ? Changed it but sure it didn't have one on
July 17, 201313 yr Part number M276. It is illustrated in the parts book, but the number is not called out it seems. As far as I know they come installed still, as my 12 bike has one, but cannot say for sure. May message Splatshop unless others chime in. Seem as they may not be totally necessary, as the(washerhead) bolt(as compared to hex screw on earlier years) is sealing to the ali case all by itself, so if it is not leaking I would not worry too much. Edited July 17, 201313 yr by copemech
