September 19, 201313 yr Trying to find the right plug for my 2012 290 and it has a denso w16ep-uh in it now. I couldn't find any charts to cross it over, is that the same as the ngk brp5...that is used in the older shercos?
September 19, 201313 yr With the NGK plugs, you can either use the BP5ES - Standard, or the BPR5EIX - Iridium spark plugs. They are not the same plug as the Denso as this is a grooved plug, but they are a suitable replacement.
