westygas270 Posted November 7, 2013 Share Posted November 7, 2013 Hi all got a sherco 2013 cabistany, have just started to notice last few weeks front end seems really strange, to put how it feels it feels like the front tyre has a puncture? but it hasnt? when you first stand on the bike to ride it front end seems really stiff and seems to have a mind of its own but not all the time then when you get riding abit doesnt seems as bad, when i took it out the garage the other day felt like headstock was stiff but then was ok? when i first got bike was spot on just feels copletley different now, has anyone any ideas ???? Quote Link to comment Share on other sites More sharing options...
lineaway Posted November 7, 2013 Share Posted November 7, 2013 Sounds like it is time (should have been done before it was ridden) to check the steering head bearings and grease them. Quote Link to comment Share on other sites More sharing options...
p@ul250 Posted November 7, 2013 Share Posted November 7, 2013 Hi first thing check your head stock bearings! If you have been using a jet washer to clean your bike you may well of driven water and mud into the bearings and any grease out. I had symptoms like your describing on a bike a few years ago, sometimes the head stock would seem stiff and sometimes it was fine. In the end I stripped the front end to find that the bearings were completely shot. Act now and you may get away with just cleaning and re greasing them. Quote Link to comment Share on other sites More sharing options...
westygas270 Posted November 7, 2013 Author Share Posted November 7, 2013 many thanks for getting back to me bikes not that old to be honest maybe 4 month old not lke its had much use but will have a look see whats happening with them Quote Link to comment Share on other sites More sharing options...
taff_d Posted November 7, 2013 Share Posted November 7, 2013 Got my Sherco 250 in the October and had to put head bearings in the following May, also check your wheel bearings Quote Link to comment Share on other sites More sharing options...
tltel Posted November 7, 2013 Share Posted November 7, 2013 many thanks for getting back to me bikes not that old to be honest maybe 4 month old not lke its had much use but will have a look see whats happening with them Maybe there has never been any grease in there, another thing to try is support the bike with front wheel off the ground and slacken off the pinch bolts, with wheel between your legs move handle bars from side to side slightly to centre the forks just in case something is stressed, Tighten up again but don't overtighten. TLTEL 1 Quote Link to comment Share on other sites More sharing options...
lineaway Posted November 7, 2013 Share Posted November 7, 2013 (many thanks for getting back to me bikes not that old to be honest maybe 4 month old not lke its had much use but will have a look see whats happening with them. End QUOTE) Totally going over the bike before you ride is what needs to be done. Spanish bikes are famous for not being greased. 1 Quote Link to comment Share on other sites More sharing options...
copemech Posted November 8, 2013 Share Posted November 8, 2013 Hi first thing check your head stock bearings! If you have been using a jet washer to clean your bike you may well of driven water and mud into the bearings and any grease out. I had symptoms like your describing on a bike a few years ago, sometimes the head stock would seem stiff and sometimes it was fine. In the end I stripped the front end to find that the bearings were completely shot. Act now and you may get away with just cleaning and re greasing them. Typical! Think I would order bearings prior to teardown! Quote Link to comment Share on other sites More sharing options...
bwmwaima Posted November 8, 2013 Share Posted November 8, 2013 Would agree with comment from lineaway, I lubed every nut and bolt on my 2013 cabestany. While doing rear suspension, found I couldn't get left hand dog bone bolt to frame mount out, as weld from centre frame up right stuck out too far, 2mm off with grinder fixed that, don't know how they ever got it in there in the first place. Other thing was swing arm axle, holes through frame and engine don't line up, had to lift axle approx 1mm to get through frame hole before nut went on. Quote Link to comment Share on other sites More sharing options...
jsp Posted November 8, 2013 Share Posted November 8, 2013 every bike I get, I strip down the head stock and fit a grease nipple then after a few washes a quick squirt of grease till it comes out through the bearings jsp Quote Link to comment Share on other sites More sharing options...
westygas270 Posted November 17, 2013 Author Share Posted November 17, 2013 will have to have a look at this highly prepped bike then jeff or JSP Quote Link to comment Share on other sites More sharing options...
canada280i Posted November 18, 2013 Share Posted November 18, 2013 Hi JSP, can you show a pic of where you put the grease fitting on the head of your OSSA, I have toyed with the idea but always wondered where the best placement would be Quote Link to comment Share on other sites More sharing options...
