Titanium Pipes
Thinking of getting a titanium pipe for my 2012 sherco 125, which is best S3 or Thor?
Thanks.
get a short one for more power - both the same really but thor make pipes for motogp and f1 so i would go with them as they specialise with exhaust pipes
http://www.splatshop.co.uk/jitsie-inox-exhaust-pipe-to-fit-sherco-2t-11-13.html
Check these out. The titanium pipes are easily crushed and will crack on the sherco due to the position of the bends.
I brought the Inox pipe as it is lighter than stock, still has a conical section to help power and stronger.
It also turns a nice gold colour when you get it hot for the 1st time.
The Ti pipes do look cool but are fragile and expensive way to save very little weight.
http://www.splatshop...o-2t-11-13.html
So do they give more power?
Also, where did you get the red water pump cover? Thanks.
Hi, The pipe will give slightly better response but my bike is a 300 with high compresion and a ported barrel plus other factory mods.
On a standard bike it will not make much difference unless your old pipe is dented or coked up.
I only changed it because my old pipe had an argument with a rock, Still cleaned the section though!!
The water pump cover is painted candy red over a silver base. It looks almost like anozised, The picture doesnt do it much justice.
I do custom paint in my bodyshop. It's not as hard wearing as anodising but it's free for me so happy days.
Okay thanks
