Front Fork Damper
hello guys am sevicing my forks i think i took them off in the correct order but cant be 100% sure can any 1 tell me wich way the spacers amd sleave go? i do have the parts book but its not very clear cheers bondy.
Maybe it's just my eyes but in the lower photo it looks like the steel cylinder that the plastic anti-bottoming cone fits into is on upside down, because I think I can see a short recess inside the end of it. I think the end with the recess should face up not down. If the cylinder is the right way around, you should be able to slide the whole plastic cone into the cylinder.
hi guys thanks for your help i did have the sleave on up side down my only other question is the space with the raised lip on it dose this face down into the recess?
