Leaky Clutch Master
Seem to have developed a leak on my clutch master, fluid seems to be leaking from around the sight glass. Anyone else experienced this and any suggestions on a fix? I am not sure if they are a press fit or if there is a O ring or are they just glued in
Fixed again
What was the reason for the leak, how did you fix it.
Had a spare half hour so with no replies I dived in and stripped it down, turned out to be the O ring so replaced it, refilled with oil and all good again with no leaks
