May 21, 201412 yr How can you tell the difference between a 2006, a 2007, and a 2008 sy250f ? Frame # ?, color of plastics may have been changed, exhaust outlets? sprocket # of teeth? Is the pumper carb on the 08 visually different than the 07? Any info appreciated. Thanks, Ken Edited May 22, 201412 yr by trials930
May 22, 201412 yr The 06 and 07 had exhaust with 2 outlet ports that came out under the rear fender. The 08 had exhaust that only exited out one port one the side of the rear fender. The 08 also came with white plastics. Not to sure on the carbs. The later 07 came with pumper cars as well. cheers
May 24, 201412 yr you need the pumper carb, any other and she is hard to set up properly. I had an 08, loved it if it was nice and grippy mightmare if it wasnt
