Side Stand
Hi, I was wondering if anyone could give me the measurements of the sidestand bolt from my Ossa mar. The chromer has managed to `lose` mine, it maybe in the bottom of the tank but it will be a while before he empties it!!
Thanks in advance, Nigel.
The original bolt is just a normal bolt but with a very thin head to clear the return spring, and a shank that is just long enough for the stand to pivot on. Probably no longer available.
I just us a normal bolt and machine the head down in the lathe, or use a button head allen bolt. Doesn't really matter if it has no shank and is threaded all the way. Can't remember though if it is 10 or 12mm, but all you have to do is measure what diameter and length you need.
Cheers Woody, mine of information, as always!!
