badams Posted October 9, 2014 Share Posted October 9, 2014 I have 1 360mm on my Yamaha TY 250 that has seized about half way on the stroke. It will compress but will not rebound. I will be rebuilding both shocks but cant seam to find the oil volume does anyone know how much volume that they hold. Cheers Quote Link to comment Share on other sites More sharing options...
eddie1 Posted October 9, 2014 Share Posted October 9, 2014 10w oil 52mm from the top of aluminum body. You will need to bleed the unit when you assemble it I have bent the damper rod on mine a couple of times causing the shock to stick. Cheap spare damper and seals from Rocksocks. They sent me an assembly sheet but its lost somewhere in the garage. good luck 1 Quote Link to comment Share on other sites More sharing options...
