2012 Sherco Return Spring For Gear Shifter Seems Broke?
2012 290 Sherco's return spring for shifter seems broken. Does it require splitting engine case for repair? Could someone give a description for repair and parts needed?
Thank You.
Sam
Remove primary drive case and clutch. The spring is at the bottom left hand side. Remove the gear leaver and clan the shaft then push it through so it comes out of the primary drive side of engine. Fit new spring and refit shaft making sure spring legs correctly engage on aluminium lug on crankcase.
Make sure you find all the old spring. usually just one leg breaks off where it is bent tightly.
You will need a clutch centre holding tool to stop it rotating whist you undo the centre nut.
Edited by dadof2
Sam,
If you do this can you take a photo of the offending area so I know what I am looking for!
My gear lever sticks in the up position so I'm guessing its the same issue.
Andy
Parts are ordered and I sure will try to get some pictures posted for ya Andy!
