November 15, 201511 yr Hi all Mikuni VM 22 carb on Tiger Cub probs When cracking the throttle wide open from a near standstill, the bike has a massive flatspot, then picks up. Now and again will stall after descending a hill. If I were to slowly roll the throttle on and off the bike is fine. Is this normal for a cub / this carb. Is anyone running this type of carb successfully, and what have you had to change on the carb to get it to run. cheers
