Seeley Fork Seals
Any fellow Seeley owners in here know the best way to change the fork seals? Just found that one of my fork legs has a serious 'ding' right where the seals sit and it looks like a welding job may be required.
The damage is so bad that most of the width of the top seal is visible, I will probably have to get a sleeve made to match the top of the leg, section it,weld it into position and machine top bore to suit the new seal.
Any dis-assembly/assembly info warmly welcomed.
Thanks again, Mark.
are these not the same marzocchi forks like the fantic?
maybe look for info/parts there...
Mark
Seeley forks use the same casting as early 125/200 Fantics and SWM's.
The only difference is that the bolt holes are larger on the Seeley, so should be ok to use.
I only have a right hand (speedo) side available.....any use to you.
Martin
www.motoswm.com
Thanks for the offer Martin....mines the bloody left side! never mind, I'll get the leg welded and machined.
Now that I know that the leg is common to a few other bikes I can always go looking for a few spares, thanks again, Mark.
