February 15, 201511 yr Does anyone know the correct procedure for reducing the springiness of the front end? I am enamoured of the plushness in the Repsol 4RT and know it wont get there but can the ossa be easily softened? thoughts?
February 15, 201511 yr Never tested a repsol so can't compare but I personally don't find the ossa front springy. I would start with the simple things like check the oil levels and bleed any air out via the bleed screws
February 16, 201511 yr Author I bleed it after use and theres a wee hiss but the manual makes no recommendations re reducing compression and rebound for weight etc
February 16, 201511 yr Have a read through some of the Gasgas manuals which have similar Marzocchi forks. http://www.trialspartsusa.com/tech.html
February 16, 201511 yr I find the forks have too much compression damping for my weight. Change the fork oil to 2.5 weight in the left leg , i find this helps
February 16, 201511 yr Have a read through some of the Gasgas manuals which have similar Marzocchi forks. http://www.trialspartsusa.com/tech.html Gary D ?
