Scorpa Fork Seals
hi noticed a leak on my left fork seal . How easy is it to change,or should i get a mech to do it
Hello. Sometimes it is a bit of grit or dirt in the seal and can be cleaned out using a film negative. I have done this with success. Certainly worth a try before stripping your forks. if you're really keen you could buy one of these !!
http://www.ebay.co.uk/itm/Seal-Mate-Tool-Sealmate-Fix-Leaking-Fork-Seals-Quick-Easy-Fast-Affordable-/121059312192?pt=UK_Motorcycle_Parts_13&hash=item1c2fb28240
Edited by rodt
Thanks for reply ,did read about film trick will try that before replacing seal
Paioli or marzocchi forks ??
Mine are Paioli, do you have any info or links to valid info? I'd like to change the oil and seals and to find stiffer springs if possible. Scorpa is '06 SY250. Any other advice would be appreciated of course.
hi it was just muck in the seal. really thin piece of plastic around fork leg then a few pumps it was sorted thanks for advice
I've had this happen twice since I bought it in January, the one ride it leaked on both legs so much in my van it left a puddle of oil (was strapped down with forks a bit compressed), bought a seal mate and it instantly stopped them leaking.
It's since sorted the left one again, so I wiped it yesterday and all good again.
I drained the forks a couple of weeks back and put new oil in, the forks felt ace afterwards.
I'm thinking of fitting some fork gaitors or tubes, where I ride the bike gets covered in crap.
Edited by sp1
My mate has neoprene fork protectors on his Gasgas they seem to do the job but there not easy to get off in case any grit got in behind them
Either neoprene or the old fashioned bellows type (which used to work just fine)
  • 3 months later...
I would appreciate any info regarding fork oil change (at least grade and quantity of oil), my beloved one does deserve it. Tks
Undo the top nut before you slacken the bottom yoke. It's much easier with the fork still clamped to the bike. First make sure you undo the top yoke bolts, as these can sometimes 'clamp' the top nut and make it more difficult to unscrew.
