Bultaco Clutch Nut
hi guys
tried to change the main seal on the bully this eve ,used a air impact gun got the crank nut off but no luck on the clutch nut
seam to be on very tight any ideas would be gratefully appreciated on the removal
are you locking the clutch mechanism with a locking tool ?
The clutch hub is very difficult to hold, you will probably need to make/buy holding device probably Inmotion or E Bay,
you can sometimes hold the hub carefully with heavy gloves & using air impact get them loose.
A tool can be made from non eared clutch plate with a suitable handle welded welded to it.
Good Luck
Larry
:agreed:
hi guys
just bought a clutch holding tool for inmotion it a Sammy miller type tool not the laser cut ones as I see on the net as they do bend a lot in use
That should help, I had to use a 3 ft long piece of scaffold tube over a wrench once to get one undone (my air wrench wouldn't touch it!!)
Looks like millerme gets around smartly by looking at the post times!!!
Good show!
Larry
hit it with a big Hammer? joking the tool will be abig help. :D:D:D:D:D:D:D
