Brake Shoes
Which brake shoes do you recommend and why ?
No it's for my 1960 bsa c15 trying to find out what's the best brake shoes or which other riders prefer .
I use the grooved Bantam / Cub shoes from Mick Ash,(RIgid Ajay,Rickman hubs) they will also go in my Ariel,(Alan Whittton hubs) when it goes together. On my last Ariel it had a Leader front hub and I got Villiers services to reline them.They were good even when wet,only gave up when they,(And me) nearly drowned at the Talmag in 2014....
If you have cub hubs I use the grooved ones off fleabay
Saftek @ Cleckheaton Yorks green gripper material is excellent, they offer a relining service.
Www.classicbrakeservice.com
Ian campbell
Relines your old shoes to whatever size you want
Tell him its for a trials bike and he will fit linings
That actually work , and work when wet... (In my experience )
He rides a classic trials bike and knows exactly what you need\want
To get the best possible brake :
1: Skim\True brake drum. Then mount oversize relined brakes on lathe and turn to fit
Or
2: not easy to get drum skimmed but anyone with access to a lathe can turn oversize linings to fit (may have to relieve lip on drum with file or die grinder\dremel )
Or
3: measure the internal dia of drum then tell ian the size and he can make oversize to fit
After that it's where do you stop ! You can get rid of ovality in pivot bush, strengthen and extend bush and mounting, alter length of arm .......
