September 20, 200521 yr Does anyone know where I can purchase an airside manifold rubber for a Keihin 28mm PWK to a 290 Sherco 05 airbox!!!! Local enquiries have drawn a blank!!!!
September 20, 200521 yr Measure size etc & go to local car parts factor. Plenty of rad hose there. Something will be close. Thats what worked for me.........
September 20, 200521 yr Does anyone know where I can purchase an airside manifold rubber for a Keihin 28mm PWK to a 290 Sherco 05 airbox!!!!Local enquiries have drawn a blank!!!! <{POST_SNAPBACK}> Yes the cessna engine has a really good hose which I fitted but I'm not sure of the part number. Will try to find out. Ordered it mail order and it was
September 20, 200521 yr ive got grimbo's 04 works 290,the one he won the schottish on,and thats got a standard air box rubber on it.what you need too do is put the standard one in hot water and then put it on the back of the carb,ok?on my son's 125 ive used a bit of subaru turbo hose,had a three mm ring made up to push on the air box.what you need too do though is leave the rubber on the carb permanant.try this and see how you get on.BIG BEN @TEAMSHERCO.COM. SHERCO'S ARE THE BEST,WITHOUT A DOUBT.
September 21, 200521 yr you do not ride an mrs sherco deejay!and are you the bloke who came a right cropper on the 1st section of bill pyes trial on sunday if you are i would be thinking about getting a 125 never mind putting a keihn carb on!love you
