July 20, 201511 yr Recently tracked down a 86 RTL250 here in the US, really great shape runs well other than the cam chain is noisy, Ive tried adjusting with some improvement but not enough. I need some help on a cross reference for the chain, is it the same as a TLR or XR ? and is front and rear brake shoes the same as another model? Thanks, Steve Edited July 20, 201511 yr by shercosteve
July 20, 201511 yr I don't know about the US, but the parts are quite commonly available in the UK from the likes of Dave Silver Spares. The part numbers are: Cam chain 14401-427-003 Cam chain tensioner 14500-427-000 Cam chain guide 14550-427-000 It might be worth getting the sprockets at the same time: Sprocket 14321-440-000 Timing sprocket 14311-KJ2-300 You'll need a small puller to get the timing sprocket off the shaft. Don't try to pull it off the shaft without a puller because it can quite easily go off square and then it's really difficult to pull off. I found that sometimes you can get a little more tension if you take off the flywheel then you can get to the cam chain adjuster arm to get a bit more adjustment.
July 23, 201511 yr The cam chain adjusters do not automatically adjust after a few years. You need to get a long 3 mm bolt to screw into the adjuster and gently pull it up until the chain stops rattling. I usually do it while it is running so you can hear what is happening. Do not pull up more than enough to stop the chain noise. The threaded end of a spoke is the correct thread size for this. I believe I saw this technique in a Honda manual or I read about it here in a different thread.
