September 26, 200521 yr HAS ANYONE RE - PACKED A SHERCO EXHAUST (2004) ANY HELP ON HOW AND WHAT TO USE WOULD BE APPRECIATED (AND IF IT WORKS) THANKS FOR ANY HELP.
September 26, 200521 yr I've heard that you can't repack a sherco, you hve to get a new one. But i would also like to know if and how you repack a sherco exhaust.
September 26, 200521 yr Check through the Sherco history on this forum which will give you photos of the task at hand. http://www.trialscentral.com/forums/index....4164&hl=exhaust
January 6, 201313 yr Cut a neat hole in the back of the exhaust with the grinder (at the top).... pull all the old out.....swill the exhaust out with diesel or similar. Pack very tightly with fibreglass. Cheap and easy! Push the cutout piece of exhaust back into the hole, slap some gasket sealant around and rivet and piece of metal over all the hole. Make sure when you wash the bike you dont get water down the exhaust....it wrecks the packing, or so im told. Hope this helps! A new exhaust is very expensive!
January 7, 201313 yr Cut a neat hole in the back of the exhaust with the grinder (at the top).... pull all the old out.....swill the exhaust out with diesel or similar. Pack very tightly with fibreglass. Cheap and easy! Push the cutout piece of exhaust back into the hole, slap some gasket sealant around and rivet and piece of metal over all the hole. Make sure when you wash the bike you dont get water down the exhaust....it wrecks the packing, or so im told. Hope this helps! A new exhaust is very expensive! Perfect-thats how I did it! Just make sure to cut the hole facing the shock/air box so it won't be in sight
