September 21, 201511 yr Chris has just bought a Tr300i and wants to replace the Footpegs. We usually Use S3 Hard Rocks but they don't seem to fit and will not flip up due to the Fingers on the bottom of the rest. Talons look right but has anybody used anything else?
September 21, 201511 yr The Hardrocks are positioned a little further forward than most standard pegs, The RQF pegs like the sherco's have standard are the same in the standard position so should feel similar. They May fit better as they are narrower at the mounting point and use spacers to take the width of the frame mounting so are less likely to bind. You can also turn the spacers around and adjust the position. They are about 45 quid too.
