September 29, 201511 yr TY350, sat open out in the weather for a bit, crank is stuck transmission is free, I have the rest of the parts minus the wrist pin. Bore and piston are perfect. If it's worth rebuilding I'll send it to B&J Racing, just looking for opinions.... I know, it's a crime but I'm not the one who did this!
September 29, 201511 yr Oh, it`s worth it. The cylinder and piston were the parts unavailable. So a little strange.
September 29, 201511 yr Author Oh, it`s worth it. The cylinder and piston were the parts unavailable. So a little strange. the cylinder and piston got pulled years ago. They were boxed and set on a shelf.
September 29, 201511 yr Author Oh, it`s worth it. The cylinder and piston were the parts unavailable. So a little strange. Spoke with Bob @ B&J Racing this morning, it's headed his way to become a seriously built engine....
September 30, 201511 yr Author Not sure, upon further inspection I decided to just send him the head, reed cage, and cylinder for a port job, reed job, head job and piston kit.
September 30, 201511 yr Are you going to be able to source a rod kit, looking at the photo the crank is likely to need rebuilding as that little end bearing looks like it will have pitting the surface it runs in & the lower bearing will be the same
October 1, 201511 yr Tony 27 is correct. No sense doing the top end and not the bottom end. There is a crank on e bay, but you still will need mains and seals.
October 1, 201511 yr Author I will rebuild the lower end myself, I have found everything I need, including that crank on eBay ;-) I figured I'd do the stuff I am fully capable of and let Bob do the rest.
October 1, 201511 yr Has Bob talked about lightening the flywheel? Makes a world of difference, depending on how hard you plan on riding it.
October 1, 201511 yr Author Yes, that will be done to this engine too. This engine is off my "parts bike" but the more I think about it, the more I am leaning toward making the "parts bike" a complete bike.... Not too much missing, front wheel, tank and seat and it would be complete. Might be kind of weird to have 3 complete TY350's though..... I have yet to pull the flywheel cover on the white framed TY, I'm thinking there have been some engine mods to it, it runs much different than the 84 stock bike I've had for years. Previous owner didn't have much info on it and he maybe rode it 10 minutes in the 3 years that he owned it.
October 2, 201511 yr The `86 was better, mainly if the rear shock is in good shape. Somebody sure tried to make it look like an `88.
October 2, 201511 yr Author The `86 was better, mainly if the rear shock is in good shape. Somebody sure tried to make it look like an `88. Yeah, not sure what they were thinking. I got it from a friend that bought it out of California a few years ago. It's an excellent running and riding bike.
