December 20, 201510 yr Can anyone tell me the best way to seal a 199a's exhaust and rear silencer joint. Is there any particular tape to use? Cheers...John
December 20, 201510 yr Hello blutaco the front manifold has a copper gasket that's that is needed make sure you tighten the nuts up even or you will bow the flange. To the rear there should be 2 small o rings on the tail off the club foot some times they work some time they don't i just smear a thick layer off sillicon round the tail put back together then leave to go off then peel the excess off sealed.
December 20, 201510 yr Author Perfect, Bondy. Just tried it with some old engine o rings triple wrapped around the clubfoot. Very tight fit. Thank you!
December 20, 201510 yr No problem been out on my 199A today rides very well not long had a total rebuild . Edited December 20, 201510 yr by bondy
