Rear Wheel Hops And Endos
Recently as my riding has progressed I have started learning front wheel hops and static balance, but no matter how hard I try I just cant get the rear wheel off the ground, or even lift it trying to do an endo with alot of front brake, the front brakes powerful and im throwing my weight forward, but can only get maybe a couple centimeters off the ground. Any help would be much appreciated.
Make sure you're compressing the rear suspension fully before you throw your weight forwards. Secondly use the clutch to provide a tiny bit of drive to the rear wheel. It will take some practice to get the amount of drive just right and time the bounce and disengage the clutch again. Good luck.
