October 28, 200521 yr Has anyone fitted a flat slide carb to an O 5 Sherco if so what difference does it make ?
October 28, 200521 yr Had the Kehin on the 04 but when I got my 05 it was so much stronger through the range thought it wasn't worth it. The dellorto is a better carb for the average rider and unless you are a top top expert doubt if you would need it. Know some of the works lads had them on but caby had the 04 front pipe too.
November 10, 200521 yr Easy to fit, Jarvis rides a fair bit with a dellorto on, last week at the peak for example.
