Sherco 290 Engine Fitting
hi  i am trying to get engine back into frame on this 2009 bike .it seems a v tight fit  if anyone has any tips i would appreciate it thanks.
Tip motor and slightly and ''roll'' into frame from side, should drop in pretty easily, dont need to force anything. The 2t is nothing...the 4t is a bit tricky but it drops right too without forcing anything in same way when you get the puzzle just right  :)
