Ty 125/175 Kickstart Seal
Hi, does anyone know the seal size for the kickstart shaft in the clutch casing?
Also can this be changed out without removing the clutch casing
Cheers
Gary
I think it's a singled lipped 17mm ID x 25mm OD x 4mm thick.
You probably could dig it put without remove the cover, but it won't be easy and you could damage the new seal refitting it.
Easy job with the case off.
Hi, thanks, got the size you said and removed the kick starter and used 2 picks, it popped right out and the new one went in without too much trouble, job done
Thanks
Gary
