August 10, 201610 yr My bike has stopped starting so I checked fuel, carburettor, spark plug and so on. I have read up about it and it sounds as if it could be the stator or the starting coil. How would I check to see if they are faulty without replacing them?
August 11, 201610 yr Splatshop has this test procedure for the Leonelli 2 map stator which I believe is what is on your bike. They also advertise rebuilding service. http://www.splatshop.co.uk/leonelli-twin-map-stator-testing
August 11, 201610 yr Author I have disconnected the kill switch and still nothing. Have gone through the test suggested above and the brown wire in the first test does not work
