October 13, 201610 yr Dear all. Can someone help id my sherco. Was told it was a 01 250cc. I recently ordered a little end bearing that came and was too big. Turns out I need the smaller 18x22x22 that is for 06 onwards. Any ways here is some info. Frame unbs129tr1a006657. engine st666657. On the piston it's stamped 04/05. On the barrel 1603713. Any help greatly appriciated. Thanks.
October 15, 201610 yr Author Cheers copemech still don't understand where u get 272 on the vin I must be durrrr.
October 15, 201610 yr Author Basically I think the engine is a 250cc cos it don't seem t have the poke my beta 270 has. Strange.
October 15, 201610 yr The 29 at the start of the frame number stands for 290 which is actually 272cc like the beta. The older 290s didn't have the power that the beta has, the beta was more of an experts bike where the sherco was a bit smoother than the 250 with more off the bottom
October 17, 201610 yr Author Cheers Tony. Is there any easy way to check is a 290 engine or not. I am not convinced it's a 290 like. Just wonder if someone has put a 250 engine in it. Cheers
October 18, 201610 yr Externally there aren't any differences, only change between 250 & 290 are piston, cylinder & head. Even the jetting is the same If you have the cylinder off measuring the bore size will tell. I don't suggest removing the head from the cylinder as you need to replace all the o-rings if you do that I'll have a look at my Jarvis cylinder to compare numbers & a cylinder off my old 01 that I have under the bench
October 18, 201610 yr Author Thanks Tony. Great help from all. I plan to replace the little end bearing when it comes. I will do some measurement thend. Keep you posted.
October 19, 201610 yr Here you go http://www.analogx.com/cgi-bin/cgivin.exe?Mode=Decode&VIN=unbs129tr1a006657&Submit=Decode
October 20, 201610 yr Or just whip the front pipe off and measure through the port - accurate enough for your purposes.
