2016 Sherco Carb set up
Hi there i have a 2016 300 with a Keihin Carb and 48 Pilot Jet and 128 main jet standard needle and needle set in middle and air screw at 1 1/2 turns out, but it seems to run on slightly sometimes i am thinking its running weak
Simple answer. Ring up Chris Pearson from splatshop, he'll put you right. And if that fails, fit a dellorto!
  • 7 months later...
Ady, How did you get on with the carb set up ? My 2016  300 Sherco has 50 and 128 had some fun getting air filter manifold to fit properly onto exhaust ended up thinking it was jubilee clip being out of shape ordered a new one.
